SOURCE: meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
SOURCE: problem with lx200gps meade telescope
It might be a voltage or electrical current problem. Make sure your DC power supply is between 12 and 14 volts. Make sure all electrical connections are tight. Where the power cord plugs into the connection panel, make sure the center pin on the panel fits tightly into the plug. It is a Radio Shack type "N" plug. If tou still have a problem, remove the bottom plate from the scope base and make sure all the connectors are properly seated on the circuit board. Check the connector on the end where the black and red wires are. That is a main power connector and if it is too loose it will not conduct enough current. There can be enough voltage drop that the drive motors won't operate, or they will and the scope will slew uncontrollaby. Be careful handling the wires so that you don't damage them. Good luck, Dave
SOURCE: Meade DS-2000 Manual Doesn't have info. about Meade Ds-2130
ds-2000 refers to the model line of the scope. ds-2130 the 130 refers to the diameter of the objective lens in mm. I have a ds-2114. Where the objective lens is 114 mm in diameter. as far as the manual goes everything else should be the same.
SOURCE: i look through my meade telescope and the things i see are small
try switching your optical lens..front to back and back to front
SOURCE: meade telestar 130mm 1020mm focal length telescope manual
All the manuals are located here--
http://www.meade.com/manuals/index.html
