Hi i was wondering will a laptop 17' screen LP171WO2 from a toshiba laptop, fit my samsung 17' R700 LTN170X2 -LO2
many thanks
brian
Different model numbers! won't fit
regards
the ribbon cable behind the screen itseft is different depending on laptop model and screen size, what you could do is compare them both to see if they are compatable, for example the ribbon conector pins that connect on the back of the screen maybe bay be different size or possibly even the same, this is trial and error but it wouldn't hurt to check.
good luck
regards
No it will not, the screens are oriented very differently from one another. the pins and the wire tapes are placed on different parts. but if you will be modifying the actual case of the laptop screen, then it may fit. but as it is, it will not fit.
hi
thanks for that the reason for the question is' the toshiba screen is made by LG and PHILIPS so it might be compatible with a samsung.
thanks for the info though
rgds bri
I have a HP LAPTOP 17,3 INCHES, AND NEED A IMPRESOR FOR IT
