I have ordered the quinny buzz 3 2012 And it gets delivered in a couple of weeks. Will the senzz carrycot fit onto the pram I have ordered???
SOURCE: does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
SOURCE: How do you attatch the dreami carrycot to the
Try this web link, it will take you to the owners manual that you can view or print out and show you the answer to your question.
http://quinnybaby.com/info_instructions.asp
Hope this helps, DutchTexan
SOURCE: Quinny Carrycot Compatible with Quinny Dreami?
The Dreami for the Freestyle 3XL is compatible with the Buzz. You will need to get a set of Buzz adapters (these are the same adapters that you would use to attach the Cabrio Fix carseat) these should cost around £18 or see if you can get them on eBay!
Hope this helps.
SOURCE: how do you fit the footmuff to the quinny buzz 3
Hi undo the harness then feed it through the holes in the footmuff, then re-attatch the harness
