Blows fine but will not heat up. It appears the gas does not kick on
SOURCE: Maytag Neptune stacking washer, model #MLG2000AWW,
you can but it wouldnt be economical to fix it if it sounds like a jet it is yr rear bearing and although the part might be only 60 dollars the amount of time it would take someone to do the job correctly is about 2-3hrs if you can do the job yourself then you would save on a large labor bill ive seen some techs price doing this job at starting prices of 400 you can find the part at marcone appliance parts if you choose to do the job yrself hope this helps
SOURCE: Hi! How do you replace
wow it's quite a job you need to disassamble the control panel area between the washer and dryer,take off the washer front panel,then reach in the back of the inside of washer to remove and install new valve and also get to the back so ya can remove and reinstall the hoses from the valve.
Wish you well i've have a few busted knuckles when doing that repair
