It charges on its own without charger whenever i put in the battery, but the phone stops charging when i switch it on. i can use it for some hours then the battery runs down,, after it warns me of low battery and i plug in the charger, it will not charge or no sign of charging. the battery totally discharges without power in it. pls help me,
There might be some battery issue you need to replace this battery to another one and please don't left your mobile while you are charging battery cells going to dead if its over charge and you will going to lose your battery and mobile as well Laptop Rental Laptop Hire in UK Wales Ireland and Scotland Hire Laptops
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
SOURCE: Nokia N73 Music Edition Charges Forever
try factory reset ...... if that does not work get it checked with the nokia service center
SOURCE: cannot power up a nokia 3110 classic. full charged battery
nokia 3110 classic.on the time of update software USB Data cable have been disconnected. and that time mobile was automatically off And after its not starts.
Please solve my problem.
SOURCE: Phone is in the charger and after charging for a
Hi, the problem is with either the phone charger or the charging port IC.. First of all, change your charger and see if the problem will still repeat itself, if it does, then you have to take the phone to a phone technician to change the charging IC.....
SOURCE: My NK5800 does not charge
Hello Anthony,
Please update the software of phone from :
http://www.nokia.co.in/support/download-software/phone-software-update?5800xpressmusic=
Also visit the link provided below :
http://www.nokia.co.in/support/download-software/device-software-update/how-to-update
