Acer Aspire 1710 Notebook Logo
Anonymous Posted on May 20, 2012
My laptop canadian multilingual standard keyboard is stuck in french
I am typing in English and suddenly my keyboard switches to French. I do not know what key I accidently hit.
3 Related Answers
Anonymous
  • 13 Answers
  • Posted on Aug 13, 2009
SOURCE: my laptop keys on
Have a look at http://tlt.its.psu.edu/suggestions/international/keyboards/winkeyvista.html.
Anonymous
  • 14 Answers
  • Posted on Dec 11, 2009
SOURCE: how do I change from French keyboard?
Start / Settings / Control Panel / Regional and language options, check you have the language you want in there, then remove the additional (French) language.
This assumes you're running Windows XP. Vista or Windows 7 will be similar.
Anonymous
  • 2229 Answers
  • Posted on Apr 02, 2011
SOURCE: HOW DO i SWITCH FROM
In the control panel there are regional and language settings. Try there.
1helpful
While typing a document in microsoft word on my fujitsu A550 laptop, all of a sudden, when trying to type / , the french e appears instead of the / that i wanted.
Sounds like you have accidentally selected a French or Canadian keyboard. You need to reselect English.
From the Microsoft web:
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clickingControl Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab, and then click Change keyboards.
  3. Under Installed services, click Add.
  4. Double-click the language you want to add, double-click the text services you want to add, select the text services options you want to add, and then click OK.
    If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
    Jim
I have a Gateway keyboard model number KU-0833. I
Hi lal1220,
I had the exact same problem with my keyboard (KU-0883). What you want to do is first go into your "Control Panel". From there under "Hardware and Sound", go to "View Devices and Printers". Right Click on your USB Keyboard and go to "Region and Language". Under the "Keyboard and Languages" tab click on "Change Keyboard". From the "General" Tab click on "Add". Scroll down to "English (Canada)" and expand it by hitting +. Uncheck "Canadian French" and "Canadian Multilingual Standard". Then press "OK". After which you press "Apply" and "OK". Give your computer a quick reboot and your good to go.
66helpful
4answers
Green function key locked on acer laptop
Hey, I've just been having this problem. Try pressing CTRL + SHIFT + FN all at the same time. I found out that I had to press them once to turn on the green keys, and then press them twice more to turn it off. I hope that works for you.
1helpful
Chose Canadin French instead of Canadian English by accident
Yes you are right: it is a one time option. You can however install other languages. You will switch from the Canadian French keyboard to the US or English Canadian keyboard by pressing Shift Alt. You will console yourself if I told you that I type mainly in French, but the physical keyboard is US and I cannot even use the Alt + Ascii code to put the accents where due, because the laptop does not have numeric pad.
Hope it helps.
When typing question marks & puctuation...French comes up
In Control Panel, double click "Regional and Language Options". Click the Languages Tab and then the Details button. Make sure that English is selected as the Default Input Language. If French is listed as an available keyboard layout and you don't need it there, you can remove it to make sure it doesn't switch itself again.
I hope this helps. Good Luck.
2helpful
2answers
Blue characters on the keyboard when I type
It is a combination of key known as "Function" (Fn, for short). You have to press it and hold while pressing other keys showing the blue letters on it. The most common use is to make a virtual Numerical Keypad on laptops, so you can perform calculations. To be back to normal mode, you need to press FN+F8 (or the key with the Calculator icon).
3helpful
2answers
KEYBOARD PROPLEM
Hi Sam,
Sorry your problem got left in the que for a while, but Lee apparently wasn't familiar with that keyboard. You do have an extra key near the start button that activates the Tags and other coloured symbols while in french or multi language mode. Simply use it like a shift key.
If you're not using the HP to type in french and don't require the accents you can change the setting in windows to tell the computer that your keyboard is a US english keyboard which will reassign all the keycodes to the "normal" locations by english speaking standards.
To do so, open your control panel, click on the classic mode link if it's not already in classic mode(20+ icons). Then click on the regional settings icon. Depending on wether you have Vista or XP the panel varies slightly XP has a keyboards tab, Vista has a Input Devices tab. Either way go to that tab and click the button to adjust input devices, on the page that pops up you will see a list of available, installed keyboards. If US english isn't listed click the ADD button find it in the list and add it.
If you only type in english, remove all other keyboards. If you use french as well, remove all but the canadian french/canadian multilingual depending which you have(if you don't know follow instructions below to find out). Then OK out of the window. OK the regional settings window and close the control panel. If you only select US english you're done, if you left French as an option you will see a small blue icon to the left of the clock, you can click on it at any time to switch between your installed keyboard modes.
Hope this Helps FixYa!
Chris
Model info for your product can be found at www.hp.com click Support & Drivers, then select the Knowledgebase button on the next screen and type in your full model number or allow the automated link to check your model online. When it launches your product page select Product Specifications from the long list in the middle and if it brings up a second list select the same.
You can now scroll down the specs and your keyboard will be listed as either Canadian English/French/Multiligual, all three have some variation of the keys you described.
2helpful
Keyboard
that means that the keyboard has been set to a different language. On my screen at the bottom right hand is a little keyboard icon and when i click on it it lets me scroll through US English, Canadian French and Canadian Multilingual Standard. If the keyboard is set to the Canadian French option (or whatever other option that is available on your keyboard in red characters) the number two button changes function.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
