see this causes and fix it. God bless you
Belt, Water Pump
If the washer won't drain the pump belt might
have broken or might have worn out. Check the belt and replace if it
shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain
pump might be defective. It's also common for a small sock or other
article of clothing to get caught in the drain pump or in the drain
hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose
If the washer won't drain there might be a
clogged pump or hose. It's common for small socks or other small
clothing items to get into the water drain system and clog the hose
leading to the pump or the pump itself. Remove the hoses from the pump
in order to remove the article of clothing. Keep in mind that any water
in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the
drive belt. If the belt is broken or if it isn't tight on the pulleys
the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch
assembly might be defective. This is a very common problem. The lid
switch assembly can fail either mechanically or electrically. Test any
electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock
assembly should be checked. The door lock can fail either mechanically
or electrically. Test any switches on the door lock with an Ohm meter.
The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the
drain hose. Be sure the hose did not get kinked behind the washer. Also,
remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may
be clogged. This washer is equipped with a device near the water pump
called a coin trap. The purpose of this device is to trap any foreign
materials that make their way down the drain. Normally, the coin trap
can be accessed through an access panel. It is designed with the
homeowner in mind and is normally easy to clean out.
washing machine was not spinning very good clothes were still wet. put in another load and stopped doing anything with 27 minutes left to go. now the door is locked and i cant get the load to finish nor can i open the door to get the water out. what do i do?????
"nd" on the digital display. front loader Neptune door won't unlock.
