If you choose to install Windows XP on the Panasonic CF52,
then please either order the original recovers DVD directly
from Panasonic, or if you wish to re-install from scratch yourself,
please use Windows XP SP3 (service pack 3) and NOT SP2.
You will find the drivers here:
Official Support Download Center of the Drivers Manuals and FAQs TOUGHBOOK...
You can even re-install with this XP SP3 CD:
Just make sure to use your Windows XP COA license located
on the back of the Panasonic Toughbook which looks like this below
Good Luck to you and Regards from:
Richard, Montreal Based Panasonic Canada Toughbook
Authorized Dealer since 1989.
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
SOURCE: i installed windows xp pro and i have no sound
Have you check Device Manager and under sound, video and game controllers to see if you have any yellow ? marks next to anything. You would go to start-control panel-system-hardware-device manager.
If you have any yellow marks missing then you will need to find the driver for those.
It may be a codec that you need too.
Also Start/ control panel/ Sounds check that MUTE is not selected and that volume is UP.
Could be these drivers that you need Audio Output: Sound card Audio Codec: STAC9751 Compliant Standards: AC '97.
Check this site and make sure you have the complete model number, There are several different ones for your Cf51 that should look like this CF-51xxxxA/H/Qxx (mk1) . Some model numbers require that you have Sevice Pack 2 or SP2 for windows installed for the sound driver to work.
http://pc-dl.panasonic.co.jp/cgi-bin/itn/toughbook/dl01.cgi
SOURCE: Is a Panasonic CF 27 Toughbook able to have
This is taken from Microsofts website directly...
These are the minimum requirements for basic functionality. Actual
requirements vary, depending on the system configuration and the
programs and features that you choose to install. If you are installing
Windows XP over a network, you may need additional available hard-disk
space.
The minimum hardware requirements for Windows XP Home Edition are:
And from what I have seen (THANK YOU for the model #) your system SHOULD be able to run it at bare minimum.
