Question about Minox Optics
The hinge on my minox binocular is so loose it will close up due to gravity alone.
3 Suggested Answers
Anonymous
SOURCE:
larry389
  • 112 Answers
SOURCE: hinge on binoculars is too loose
there is a hinge nut at the bottom of the hinge..sometimes you have to turn of the cover or peel back the rubber to get at it
Posted on Feb 20, 2009
Anonymous
  • 43 Answers
SOURCE: nikon compact binocular 25 years old. The hinge
Does this pair have two parallel tubes with a bridge in between?
If it does, then removing the caps at the eyepiece end of each hinge will reveal a grub screw. Tightening these will add tension to the hinge and give you the proper feel once more.
Posted on Mar 02, 2010
Can I get a replacement eyepiece for my minox binoculars
Here is the link to Minox Repair Service with addresses and phone numbers to call for answers:
http://www.minox.com/index.php?id=4902&L=1
May 21, 2012 | Minox Optics
How to tighten binocular hinge
Simple solution: Pry or unscrew the cap covering the end of hinge shaft on the rear of the binocs (between the eyepieces). Use a screwdriver that fits snugly in the slot on the end of the shaft & tighten to desired tension. Place a dab of Goop-type cement on the inside of the cap if it was pried off & press it firmly back on the shaft . Helpful hint: Slide a small knife blade (an old dull one you don't use for cutting) under the cap and gently work your way around to pry it off. Note the position of the index numbers before you remove it so you can replace it in the same position.
Feb 27, 2012 | Nikon Monarch ATB 7345 Binocular
Eye alignment loose for eye centres
sounds like center hinge is loose..has to be taken apart to repair ..larry@reichinstruments
Jun 05, 2011 | Zeiss Classic B/GA 524013 Binocular
The left eye piece on my Minox 8x32 binoculuars isn't working properly. It doesn't adjust. How can I get it repaired?
In the US, you can contact Minox at 603-469-3080. You'll likely need to send them to Minox for repair service. Their offices out based out of New Jersey.
Regards,
Ben
Ben Lizdas
Sales Manager
Eagle Optics
www.eagleoptics.com
Dec 15, 2010 | Minox BD (8x32) BR asph. Binocular
Nikon compact binocular 25 years old. The hinge
Feb 28, 2010 | Nikon Optics
My ed25pqxfwo2 fridge door seems slightly lower than freezer door.gravity not closing door. do i need a new bottom hinge?
You got a worn bushing you could try and make one out of PVC. May just be a loose hinge.
Jul 30, 2009 | Whirlpool Refrigerators
Loose hinge _ Bushnell small binocs - 8 x 21; 392 FT at 1000 Yds.
Bushnells are inexpensive binoculars. A repair would cost more than a new one. If they are out of alignment to have them collimated would take time and that translates to expense. Its not something that can be done at home without a collimator. New ones similar to yours can be found online for between twenty to forty US dollars. Binoculars today can be bought much cheaper than a few years ago. If you are happy with the use you have had from your Bushnells an update won't break the bank.
Jul 18, 2009 | Optics
Binoculars are too loose to hold eye to eye spacing/
under the bottom hinge cover there should be a hinge nut you can tighten, if i can help further call 5088331232...larry
Jun 12, 2009 | Bushnell Binoculars - Off Trail Compact
Hinge on binoculars is too loose
Feb 19, 2009 | Nikon Sporter I Binoculars
I cant find friction adjustment on Minolta 10 x 40 binoculars
Hi Ray:
I have Minolta binoculars with the same issue, I believe that I also have the same Minolta model: 10x40mm, roof mounted prisms, 5.6 degrees, waterproof (WR series) and model number j-b35.
Have you found any solution for the loose center hinge?
josch799@yahoo.com
Feb 01, 2009 | Optics
Optics Logo
153 people viewed this question
Top Minox Optics Experts
Marvin
Marvin
ray gallant
Are you a Minox Optic Expert? Answer questions, earn points and help others
