SOURCE: remove paper from adf error ricoh aficio 2020
Clean the paper sensors and move the actuators.Open and close front door to reset malfunction.
SOURCE: Ricoh Aficio 2020 All-In-One - printer offline
Under printer check book unmark Use printer offline
SOURCE: i have a Ricoh aficio
The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
Check that the toner bottle is empty and most of the toner in the development unit is depleted.Add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
