I have a ps3 wich is connected to a sony bravia tv through a Belkin HDMI cable. But right now the HD video and everything works just fine, although there is a small problem. The Output of my TV is connected to an Onkyo 5.1 Home theater system. But i cannot get the 5.1 surround sound output when playing games on my ps3. Can u please help..?
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
SOURCE: No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Testimonial: "very fast, thanks for the help!"
SOURCE: I get surround sound whenever i'm playing dvd's.
just plug your satellite and dvd player in to your tv. and simply take an extra set of red, white, yellow wires and us use the red and white wires to connect fron your tv output to your surround sound system's input. now you should have surround sound for everything included local tv stations from your tv antenna
Testimonial: "this worked perfectly...thanks for all your help!! made my day!!"
