Roland Boss DR 880 Dr Rhythm Drum Machine Logo
Anonymous Posted on May 22, 2012
Boss dr 880 a,b, outputs no sound when switch from internal master assign
Boss DR-3 Dr. rhythm LED screen lights up by does not show any information. what can I do to fix problem?
take it appart. there is a conductive rubber between lcd pannel and the pcb use widow washer fluid without amonia to clean it
tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
My boss BR 1180 digital recorder has suddenly stopped playing back in stereo. Sound from left side only. I checked older recordings on the machine and it does the same thing. VU meters show sound on both...
  1. Check the Headphone Output:
    • Make sure that the headphone output jack is clean and free of any debris. Sometimes, dirt or dust can accumulate and affect the signal.
  2. Output Mode:
    • Double-check the output mode settings on your Boss BR 1180. There might be a setting that affects the stereo output, so ensure that it is set correctly.
  3. Output Routing:
    • Verify that the output routing settings are correct. Check if there's a setting that might be causing the output to be directed to only one side.
  4. Master Output:
    • Check the master output settings to ensure they are balanced. If there's an imbalance in the master output settings, it could affect the stereo playback.
  5. Factory Reset:
    • Consider performing a factory reset on your Boss BR 1180. This can often resolve software-related issues that might be causing the playback problem.
  6. External Monitor:
    • If possible, connect the recorder to an external speaker or monitor system using the appropriate outputs to see if the issue persists.
  7. Contact Support:
    • If none of the above steps resolves the issue, it might be a hardware problem within the unit. You might need to contact Boss support or a professional technician for further assistance or repairs.
Feb 05, 2018 • Music
Im not getting anything from my djx700 master output, getting sound from booth output. what could this be
The first thing I would look at is the kill switches on each side, make sure these are not pressed. Also make sure the master fader is up. I would disconnect anything that may be plugged into the effects loop send and return. Make sure the main outs are plugged in correctly, the main master outs should go to a power amp, this unit appears to be a unpowered unit. Make sure you are using the proper cables to avoid damage, lookup and understand the difference in speaker cords and instrument cords and place them properly. Also make sure the "assign A" and "assign B" are positioned correctly. Hope this helps but, if you give me a little info on how you are using this unit, I could help you further, please.
Backlight on boss dr 880 failed
IM LOOKING FOR A LCD BACKLIGTH REPLACEMENT PART
I was needing the instruction manual for a BOSS DR 550 MK II Drum Machine
The DR-550 MkII is the upgraded version of the venerable, original DR-550. ... Also, as in other drum machines in the DR-series, you can chain patterns to forms songs - In the DR-550 MkII, up to 8 songs ... Boss DR-550 Mk II manual. Available ... www.synthmania.com/dr-550mkii.htm
Just checked this site. I am sure this manual is the one you want
Feb 20, 2012 • Music
Need operating manual for BOSS Dr. Rhythm Section DR-5
Here is one link:http://cms.rolandus.com/assets/media/pdf/dr5_turbo.pdf Here is more:http://www.rubiconsystems.com/paul/dr5faq.htm
Jun 28, 2010 • Boss Music
1helpful
1helpful
My boss digital delay works when engaged but no sound when not
sounds like the true bypass line has been damagd. Should be easy enough to fix. Pop open the unit and do a visual inspection first, if nothing is noticeable then do a continuity check with an ohm meter from input to output with the delay efffect off. If you don't read a short in this situation then your problem lays within the signal path and its switched path.
2answers
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
