Question about Olympia Manual Typewriter
My old manual Olympia typewriter always stops in the middle of the carriage when typing. If I hit the shift key it will move forward and I can continue to type. What is the mechanism that makes it s
My typewriter is in fantastic shape, except that it always stops in the middle of the carriage when typing. By hitting the shift key, some mechanism is released and I can continue typing. I just want to know how to permanently disable this stopping mechanism. Any suggestions?
  • 482 Answers
The carriage is touching the cavers it need the flat rubber washers that are between the case and the frame look at the bottom of the typewriter remove the screw slip in a new washer and replace the screw do the same on the other side
Posted on Feb 11, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
Posted on Sep 02, 2008
Dick O Reilly
  • 3594 Answers
SOURCE: Carriage remains stationary when typing. Is there a way to unlock
Mant portables have a lock to hold the carriage in place while in the case, on the rt. or left sides below the carriage.
Hope this helps
DickyO
Posted on Apr 14, 2009
Dick O Reilly
  • 3594 Answers
SOURCE: Unit is Olympia Electronic Report Typewriter. 1983 dated manuals
Sounds like a bad keyboard or a spill in the keyboard.
DickyO
Posted on Jul 19, 2010
Andrew Houle
  • 125 Answers
SOURCE: I have a very old Olympia portable manual
Hi:
Parts are not going to be available for that typewriter anymore. That means you have to get creative. Either go to your local hardware store or a Home Depot. and look for rubber bumpers that you might affix to the bottom of something to prevent it from scratching a surface. Yous should be able to find something like that in the hardware section.
Andrew
Posted on Sep 02, 2010
SIRKNIGHT971
  • 23 Answers
SOURCE: I can't unlock the carriage on my old Olympia typewriter
YEP, MOVE THE PAPER FEED SELECTOR TO NUMBER 1
Posted on Sep 17, 2010
How do I increase the area where I can type?
Press margin release key, move carriage using backspace to where you want the left margin to be and press left margin set key. Repeat for the right margin, use space bar to advance the carriage and press the right margin set key instead.
Sep 10, 2014 | Olympia Startype 3 Typewriter
I have an Olympia Progress manual typewriter. It seems to be in good working order, well oiled and good action in the keys, except the carriage won't advance when I type. I don't believe the...
try typing with a little pressure on the carriage (push with right hand to the left) if it work like that then the carriage pull cord may be broken
Apr 23, 2013 | Office Equipment & Supplies
It's stuck in place and won't move either left or right. When I hit a key it types that letter, but the paper doesn't move to the next space
If it is stuck in the middle of the page it probably has a carriage lock usually just below the carriage on the R. or L. side.
DickyO
Oct 12, 2011 | Olivetti Lettera 35 L Typewriter
Typewriter problem
IF THE CARRIAGE IS NOT MOVING LEFT OR RIGHT, CAN YOU PUSH THE CARRIAGE TO THE RIGHT OR LEFT??? OR IS IT COMPLETELY STUCK. YOU CAN TRY CLEANING THE SILVER SHAFT THE CARRIAGE SLIDES ON AND LUBRICATING THE SHAFT WITH A LIGHTWEIGHT OIL, WHEN YOU PRESS THE KEYS DO THEY WORK.???
Mar 18, 2010 | Olympia Mastertype 3 Typewriter
I have an old Hermes 3000. I was in the middle of typing away and the machine was working perfectly. Then all of sudden the carriage will no long stop. It just slides directly to the right margin and stops...
It might be that you tab key is engaged which would do this. also try gently moving the carriage to a point, pressing the space bar and then releasing the carriage. It might be the escapement..
Hope this works!
Dec 09, 2009 | Office Equipment & Supplies
Hope this helps
DickyO
Apr 14, 2009 | Olympia Office Equipment & Supplies
Ribbon for Olympia de Luxe portable typewrter
go to "www.google.com", in the box type "olympia de lux typewriter ribbon" then hit "go" you should find plenty
Dec 02, 2008 | Olympia Mastertype 3 Typewriter
Olympia Manual Typewriter Logo
201 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
