AEG 23 in. 6410KF-N Electric Cooktop Logo
Posted on Nov 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hob turns off
Hi,can anyone help with the problem i'm having with my aeg electric hob. If i turn all four rings on as it heats up either the left side or the right side switches off untill ithe coool down.
There isn't any error displayed, i have tried switching the hob off and on a few times this hasn't made any difference.
can anyone shed any light on this problem please.
Thanks AL.
gerbee gomez
Level 2:
Novelist:
  • Expert 222 Answers
  • Posted on Dec 02, 2008
gerbee gomez
Expert
Level 2:
Novelist:
Answers
222
Questions
0
Helped
139226
Points
388
Hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
2answers
5helpful
3answers
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
6helpful
Turn hob on and only get letter L on each hob and will not turn on
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
2helpful
2answers
Hob says 'L' when turned on, tried solution but still not work
i called up AEG customer service, and they said: Press the '-' and bottom right '+' sign and this should take off the childlock. So it looks like there manual was correct. It seems like in some cases you need to do this, or the method suggested in the other post
19helpful
3answers
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
13helpful
4answers
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
4helpful
Indicators
the 'L' means locked - to unlock turn on hob, hold down front right hand side plate control and minus botton to unlock - see manuals for further details
2helpful
2answers
Hob not working
It is child lock.
2answers
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Top AEG Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
