SOURCE: Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
SOURCE: Fuji 45fd -- internal memory full. How do I
It should read the card as soon as you insert it.
