Canon tech support for faxphone L80 --- will not fax multiple pages --- multiple pages are faxed as 1 page
If you have time and small amount of skills do the next:
Open cover of keyboard panel ( pull towards ), then you will be able to see, on fax side two rollers, and on keyboard side one separation assy ( rubber piece grey or black color ), as first aid use mild sand paper and "scratch" on it and clean with alcohol.
Also clean the rollers on fax side, while turning them.
This is only as first aid. If then works, that means that you need to order and replace separation assy. For EU code is HG5-1308-000.
TIP: when you replace sep.assy, also tighten the spring wich holds separation assy.
