Question about Sharp Office Equipment & Supplies
Plz my newly bought sharp am 410 say printer error fuser temp. How do i fix it?
    Guru:
  • 558 Answers
You can Fixitout by simply power it off and after 2 minutes power it on. Check the Computer for any device driver fault. If everything seems Ok, then shoot a Print and check.
Post further comments...
Posted on May 23, 2012
  • stonepeter May 23, 2012
    It persist since i bought it about 4 month ago. Av off and on several times
6ya staff
SOURCE:
Anonymous
SOURCE: printer error, fuser temp
It is giving me an error message of "printer error,fuser temp"
Posted on Sep 15, 2009
Anonymous
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
mitesh ramboros
  • 78 Answers
SOURCE: model - Xerox phaser 3100mfp - while installation
could be faulty fuser.or you could remove and re instal fuser
Posted on Nov 30, 2009
Rick Kasper
  • 2072 Answers
SOURCE: printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Posted on Mar 10, 2010
sisodiyaraj1
SOURCE: Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Posted on Jul 04, 2010
Sharp AM-410 no toner error
error AM-410 replace toner ?
Dec 26, 2011 | Office Equipment & Supplies
Sharp Am - 410 Copier & Printer " Fuser Temp" error message
My Sharp printer AM 410 is showing in the header fuser temp error what show I do
Jul 07, 2011 | Office Equipment & Supplies
My sharp am 410 photo is saying printer error fuser temperature
try to put your printer in well aspirated place 3 inches away from wall uncover any ventilation slots on printer`s body
May 29, 2011 | Sharp Office Equipment & Supplies
Screen displays "printer error fuser temp"
Disassemble fuser unit and inspect thermistor and thermostat for dirt or damges, and heater lamp for damages.
Good luck.
Feb 08, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Sharp AR-235 shows error H4-00, would like to know how to fix without costing me.
Noy likely you can fix this without replacing the fuser lamp H4 means the fuser lamp is not getting to temp. It cold be a fuse on the fuser unit,too. Checking with an ohm meter is only way to know which,
Feb 07, 2011 | Sharp AR-235 Copier
LET'S START
PREES- MENU BUTTON
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
OK BUTTON
Mar 12, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
Error H-4
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and sometimes the temp sensor jammed.
Only when the problem is a jammed temp sensor or a jammed control board you can reset the machine by doing a reset.
You try reset from simulation mode by following procedure below:
Clear key >>Interrupt key >> "0" key >> Interrupt key >> Main code >>Start key >> Sub code >> Start key
If the error remains, that means that the fuser is really bad and must be replaced.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Mar 01, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
110 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
