My dad's favourite razor is a 10 year old Philishave hq 4865 which now needs a new battery, any ideas where I can get one? I live in Nova Scotia Canada. Thanks
SOURCE: I have a philishave hq 6849 which is about 5 years
Yes, there is an internal battery and it can be replaced. You will find the battery you need at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
You will need one or two batteries depending on the internal configuration of your model.
To open the shaver, you will need to remove the two screws on the back of the shaver. Once the back cover is removed, you will be able to access the battery pack and circuit board. You will need to unsolder the old battery pack from the circuit board and solder in the new one
SOURCE: how to remove batteries from a philishave razor
You will find the correct battery type for model 6863XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
SOURCE: how do i open the
You will find the correct battery type and helpful installation video at shaveroutlet.com. Click on link below and scroll down for video
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
YOU ARE IN THE INCORRECT PRODUCT CATEGORY
I'm sorry but
you have this posted in the wrong product category. Please re-post
the question in the proper category This is the car and truck problem
category
