SOURCE: Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
SOURCE: slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part: http://www.shopjimmy.com/catalog/product/view/id/169673/s/sony-a-1376-788-a-bm-board-for-kdl-32m3000/
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Dave
503-432-9904
Premium TV Tech
www.pleasefixitdave.com
[email protected]
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
038
533
679
505
533 038 039 064 102 130 505
Ok.
