Computers & Internet Logo
Posted on May 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mine is hcl motherboard p4 and 516 mb ram.......what is my ram type?? configuration??
Shawn DuRee
Level 3:
  • Master 356 Answers
  • Posted on May 24, 2012
Shawn DuRee
Master
Level 3:
Answers
356
Questions
Helped
131924
Points
1300
Download the free program called belarc advisor and run it. it will tell you exactly which type of RAM you have.
2 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Aug 30, 2008
SOURCE: ram upgrade
go to the site below then run the system memory programme and it will tell you the type and amoint that can be fitted
click on scan my system
http://www.crucial.com/uk/store/drammemory.aspx?gclid=CKvN352WtpUCFQyD1Qod6in5Pw
Anonymous
  • 127 Answers
  • Posted on Mar 18, 2009
SOURCE: I need to improve my pc with Motherboard PT800A-8235/7
hears alink for some ram very good i use myself
http://www.crucial.com/uk/?cpe=pd_google_uk&gclid=CKGun-PWrZkCFYQ-3godUX8mJw
hope i was helpfull
good luck
Can i upgrade my hcl laptop into 1 or 2 gb ram and processor,it has intel celeron M360 1.4 Ghz,clevo M360S motherboard,512 mb RAM ddr
Hi sadananda11i,
Yes, you can upgrade your laptop memory.
Hope this helps.
Thank you for using Fixya
1helpful
2answers
Known good processor listed on HCL Known good memory listed on HCL Powers on No video
3.80 GHz800 MHz 2 MB pentiam 4
3.60 GHz 800 MHz 2x2 MB for D processer
RAM
1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
8 GB maximum total system memory using DDR2 667 or DDR2 533 DIMMs
4 GB maximum total system memory using DDR2 800 DIMMs
Minimum total system memory: 512 MB
Non-ECC DIMMs
Serial Presence Detect
DDR2 800, DDR2 667, or DDR2 533 MHz SDRAM DIMMs
Or follow the link
http://www.intel.com/support/motherboards/desktop/dg965ot/sb/CS-026605.htm
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Additional 128 mb ram is not reconignies in ram slot
Remove all RAM, and eseat the new 128 board.
The new board MUST be :
128MB (1X128MB) PC100 NONECC UNBUFFERED 168 PIN SDRAM DIMM
If the criteria is anything but the configuration above, it will not work.
Also because of the type of memory, I am guessing the age of the board (or system) check to see what the max RAM is and see if your new board exceeds that amount.
Good luck.
1helpful
2answers
Pls tell me mb driver for xp2000 hcl
Just go on the flowing link for download the HCL Desktop & Laptop driver
(www.hclsupportservice.in) HCL Driver site http://203.76.139.132:8080/examples/jsp/download/pon_index.jsp
(It’s free) and mail your quarry on [email protected]
Thanks
Abhay Singh
2answers
ASUS P5VD2-MX SE recognizes only up to 2500MB RAM
Actually you are doing better than you think, According to your MB specs it is only supposed to hold a max of 2GB (1GB per slot). The updated BIOS may be allowing for the additional 500MB.
If you would like to verify, here is a link to the manual for your MB:
P5VD2-MX SE Manual
See page viii.
Thanks for using Fixya.
Wayne
1helpful
2answers
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Memory cards
Normally 512MB is a good configuration of Ram to work with Windows Xp Sp2 but you have clean your temporary files frequently
Increasing RAM will not give you much speed difference because first you have study the Motherboard Bus speed and the cache memory - Actual speed increase from those things and the compatibilty.
Changing Ram you have to determine what type of ram and its bus speed whether its a SD Ram or DDR1 or 2 I hope now days SD ram cost more because its outdated and DDR1 is also bit costly than DDR2.
Hothawk
3answers
Problem upgrading RAM to Intel D845GLLY
Most likely the memory is incompatible or in the wrong configuration. Check here to see the proper configuration for this motherboard.
Grand Canyon Tech
Grand Canyon Tech
