We have the above washing machine. Its about 9 years old, and has done us well over the time. No problems until today! The front door remains locked - and the light doesn't go out, even if the machine has been been turned off for ages. So we can't get our washing out. However, the main issue is, it doesn't even start to wash when you press the start button. We've looked for the error code, and we think it's manifesting on the programme phase indicator lights. The flashing lights are is Wash, Rinse Hold and End. (ie 2, 4 and 8) What does this mean? And what can we do to fix it? I have drained out all the water from the machine, and have cleaned the water in filter. Thanks
SOURCE: Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
SOURCE: wont start on any program
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Water from faucet shd be in good pressure. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
& rate me pl.
SOURCE: Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
SOURCE: Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
