Hi
Gary, It is possible that your ground fault plug is at fault itself. Sometimes the
GFIB becomes weak and will
trip off without there being a real problem. Some
GFIB are rated at 15 amperes and some are rated at 20 amperes. I would recommend that you check it out and make sure that your
GFIB is rated at
20 amperes and is new. Even though a
GFIB might be rated at 20 amperes, the fault condition that allows the
GFIB to trip is a very small amount of current detected between the safety ground...the round hole and the neutral (the larger vertical blade). The 'trigger' circuit is looking for any current flow between the safety ground wire and the neutral wire and that will probably be in the range of 100
milliamperes and above.
FYI, refrigerators and washing machines do not like GFIB's Bottom Line: You can make your washer operate on your
GFIB plug by using a
ground buster which is an adapter which you plug your washer power cord into the
ground buster and the ground buster into the wall
receptable. Please keep in mind that if you use a
ground buster.....your washer will not have a safety ground. Hope this helps you!
Handy Henry If you need further help, I’m available over the phone at
https://www.6ya.com/expert/henry_239f63a136de60f0
I replaced the ground fault and it tripped it as well.
