I have toshiba black & white copier model: e-Studio-232. Just one problem copier still there wait adding toner, after few minets display showing (Install new toner catridge). email: [email protected]
SOURCE: how to reboot my toshiba E-Studio 232 black and white copier?
if u want to reboot hard **** just go to 08 mode .then press 690 press start .2 is normall format .shut power off when reboot machine appears .
SOURCE: Toshiba e-Studio 232 Black and White Copier C430
Fuser Unit problem. The fuser is the part that heats up and is located right where the paper exits the machine. Most common problem causing this code is the thermistors go bad. You most like need the 2 thermistors replaced in your fuser unit.
SOURCE: toshiba e-studio 211 copier .Toner sign not remove
Machine shows "Toner not Recognized" when correct toner is inserted into MFP.
It can be due to main PCB faulty.
SOURCE: toshiba e-studio 255 add toner blinking after changing new catridge
did you shake toner cartridge really well... assuming that you have, was the copier allowed to run on 'fumes for a while before replacing Toner? if yes then switch off and back on a few times to allow the Toner levels back up to normal level... (replenish) if all that fails then you will have to call an engineer as it is possibly a faulty sensor on the DV unit.Steve (copier engineer 27years)
its working but not copying ..paper comes out blank with black scratch mark only. Cartage new..every thing welll loaded , what to do.?? Pl.help URGENT . nEW dELHI.
