Hi on my tv we lost the remote control, and the side buttons all seem to work to the touch,except for the channel up and channel down buttons. I do not get any reaction when touching these 2 buttons? Is this an easy fix? I am relatively good at working on things and repairing with general knowledge...thx
SOURCE: Programming Scientific Atlantic remote to work with New Dynex TV
dynex is bestbuy's product try emerson, mine is working with emerson codes
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
SOURCE: Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
SOURCE: my dynex remote control for 32 inch flat screen
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
SOURCE: Dynex dx-l40-10a flat-screen hdtv turns on and the
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight. With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing
I hope this helps.
Testimonial: "thanks"
