Hello Li-Ion batteries can be bought from most of the electronic spare part selling shops at your town. Check its specifications, ie, voltage, amperage, size etc, before buying a new one.
You can only make yourself a new one. The
Che-ez brand went out of business a few years ago and there is no hope
to buy a replacement battery from the market. This solution only works
if you have the original Li-Ion battery with you, as the plastic frame
is needed to re-build it. Strip the outside labels on the non-working
battery by hand to expose the battery cell pack and the overcharge
protection PCB (circuit board). With extreme care, unsolder both off
the plastic frame from the inner side of the battery's electrical
contacts. Go on ebay and buy a generic Li-Polymer cell pack (search
"Lithium Polymer Battery 3.7V 380mAh for MP3 MP4 SAT NAV"). Again with
extreme care solder the two wires sticking out of the new battery pack
back into where the old cell pack came off (check polarity carefully).
It is a bit oversized but it will still go into the battery slot without
much problem. If you have done even right, you should now have a
working camera again.
Make yourself a new one. The
I think the Che-ez brand went out of business a few years ago and there is no hope to buy a replacement battery from the market. This solution only works if you have the original Li-Ion battery with you, as the plastic frame is needed to re-build it. Strip the outside labels on the non-working battery by hand to expose the battery cell pack and the overcharge protection PCB (circuit board). With extreme care, unsolder both off the plastic frame from the inner side of the battery's electrical contacts. Go on ebay and buy a generic Li-Polymer cell pack (search "Lithium Polymer Battery 3.7V 380mAh for MP3 MP4 SAT NAV"). Again with extreme care solder the two wires sticking out of the new battery pack back into where the old cell pack came off (check polarity carefully). It is a bit oversized but it will still go into the battery slot without much problem. If you have done even right, you should now have a working camera again.
WHAT TYPE OF PLAYER IS THIS??? WHAT IS THE DIMENSIONS OF THE BATTERY??? CTA DIGITAL MAKES A UNIVERSAL DVD BATTERY FOR ABOUT $50. ( radio shack isn't as good) ctadigital.com DVB-EXT
