I AM NOTICING THAT MY DIRECTV HD DVR IS DELETING MY RECORDED PROGRAMS AND IS REGISTERING IN MY HISTORY PAGE AS BEING DELETED BY VIEWER AND I DID NOT DELETE THE PROGRAMS, HELP !!!!
SOURCE: Reciever Not Recording
Turn off the receiver, unplug the receiver, wait 30 seconds, plug it back in, and go through the setup again. This hard restart clears the memory and restarts the DVR software(clears any software glitches) This should fix this problem assuming that your satellite signal is good. Check that during the resetup. Most transponders will show between 70 to 100 signal strength. (Minimum is 70 for error free reception) Several transponders will show 0 as they are dead on the satellite, and not a receiver problem) If your satellite signal is in the 70's or less, you either live in Maine or you may need to realign the dish or something is blocking the signal like a tree or bush growing that is partially blocking the signal causing the signal to drop out(partial recordings)
SOURCE: DVR recording problems
i am not terribly familiar with these systems but there are probably two sattelite in ports on the back of the receiver, one is a line for watching one program or recording, the other strictly for recording, one of these inputs is probably no longer receiving signal
SOURCE: My Directv DVR receiver will not stay on it is blinking yellow??
Unplug it from the power for about 30 minutes and then try again. If it still doesn't work I would call DirecTV and discuss getting it replaced.
SOURCE: directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
SOURCE: Can I get my recordings off a HD DVR with a damaged hard drive?
Sorry, no. Not unless you have a working unit you can put the faulty drive in, but as you say, it's faulty... by its nature a faulty drive isn't useable.
