If picture only one side or only top or bottom set uses two boards to drive the screen, either one of them is bad or the actual display panel itself--it is the entire screen unit where the picture is displayed.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
It will be best to contact the authorized service center for LG in this case. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
Check its speakers first. If they are found OK, check and replace the audio output card. Check the voltage to this card from main power supply regulator board.
Hello, The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
LG 50PC5D-UL Plasma TV.... While playing XBox360 the screen just shrunk to the top 3" as though some one was holding a towel over the bottom portion of the screen. I have unplugged all inputs and the unit. I have let it cool down. Still it remains in this condition. I can't see the menu because it's in the portion of the screen that is "blacked out". What do I do?
