Question about Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Television
Sony tv screen has no picture
The screen has no picture, has red light standby, when go to switch on, green light flashes briefly, then no picture
    Top Expert:
  • Sony Master
  • 14,553 Answers
Watch the red light and or power light when this happens, if there is a specific number of blinks and then a pause that is a error code.
Posted on May 25, 2012
Anonymous
SOURCE:
Anonymous
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
Anonymous
  • 203 Answers
SOURCE: Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Posted on Sep 11, 2008
Anonymous
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
electroman
  • 1039 Answers
SOURCE: 13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Posted on Apr 25, 2009
Anonymous
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
Standby/timer flashes and screen goes black
How many times do this standby light flashes at one time switch ON? Count it. These flashes are fault indications. From the number of flashes, you can get an idea about which section circuit inside it is faulty. After confirming it, If you wish to get more details of these blinking codes, check this link.
Mar 02, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
Flashing "Standby" light??????
KP53HS10, NO PICTURE OR SOUND , ONLY A CONTINOUS BLINKING RED LIGHT ON CONSOLE. CAN YOU HELP ?
Nov 12, 2009 | Televison & Video
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Jul 02, 2009 | Sony Televison & Video
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
May 19, 2009 | Sony Televison & Video
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Open Questions:
See all Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Questions
Sony Bravia KDL-46X2000 46 in. HD-Ready LCD Television Logo
344 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
