SOURCE: Having had my tomtom one
The problem is solved but why would i tell you how to do it for free when you wanted to charge me for your advice what do you think i am stupid.
SOURCE: product code
HELLO
try this it's normally for 6.75 1409 map
M2WVZ FZUJQ 2KDZW
or those
SNFHD BV3UL HCRZ2
C6CZH LJGM3 54H72
Bye let us know if it work
SOURCE: cannot get map to work
First make sure you have a backup of your NEW ONE XL. You should be able to connect your XL to your PC using USB but not use TomTom home software. Your TomTom should appear in "my computer" as a drive . OR , put the SD card in a USB reader connected to a PC , that way you can look at and copy from or to the SD card.
You should be able to copy the map you have to the SD card directly ( if there is enough room on it ) , if theres not enough room , get a new bigger card , copy all the backup files you already have on your PC + the map you want. You might / should be then able to activate that map in the XL using the codes you say you have for the maps. if you try to do this using TomTom home it might have some restiction to stop you activating the required map but hopefully you should be able to do it manually as described above rather than use TomTom home. ... GOOD LUCK .
Please rate this reply if you find it useful .
as the unit is second hand i have no product code to activate it any ideas
