I just removed the card by pushing it n i was successful, but while inserting back the card i couldn't n by applying force i was able to insert it again. but today when i wanted to eject it again i failed and i had to pull it. Will my camera work with the memory card or not. Please do tell me
SOURCE: "Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
SOURCE: SDHC card won't work
firstly does the camera support 8GB? if it does the card may have the "write protection" switch on, take the card out and check this, after you have checked it put it back in the camera and format the card using the camera menu
kind regards
SOURCE: We insert a memory chip into our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
SOURCE: Took pictures on camera without inserting card, no cord
Yes, there is.
Insert the card into the camera. Make sure the storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
Note: this process is actually a copy, not a move. The originals will still be in internal memory. After you transfer the pics to your computer, you can then delete them normally.
To change the storage location, press the Menu button. Press up/down to highlight Image Storage, then press OK. Select Internal Memory and press OK.
Testimonial: "Exactly what i needed to know. Thanks!"
