SOURCE: battery charger
Take your charger out on a boat and dump it into the sea. Then go to the store and buy a new one.
SOURCE: 18 volt ryobi battery charger...green & yellow lights come on wha
talked to Ryobi and they are vague. It can either mean that the battery is bad, or the charger is bad and another one that maybe the contacts of the battery are dirty or not seating fully in charger. What I would look for in this instance first unplug the charger and look into charging slot to make sure the terminals of the charger are not bent and they come out into the cavity where battery would go. If not gently pull terminal into opening and retry. Sorry I couldn't be of more assistance
SOURCE: can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
SOURCE: Charging an 18v battery with a 14.4v charger
No, absolutely not! But it won't charge it either.
SOURCE: will 14.4 volt charger charge
I'm afraid not. It will damage the battery if you try. You'll need to get the correct charger.
