SOURCE: TOSHIBA RDXV45KB
This is a disc read problem the discs recommended in the manual seem to be the only discs that will work on this machine.
I was getting the same error code everytime but the disc that i know does work is a Verbatim 16X DVD-R.
These discs work in all situations on my machine , dubbing and direct from TV.
SOURCE: Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
SOURCE: Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
SOURCE: Cannot record onto DVD
we are borrowing the unit and do not have the user manual. we cannot figure out how to record a self made vhs to a dvd. how do we do it? please help, its for a project that is due tomorrow.
