SOURCE: no picture on the screen , but sound is good and I can not see the functions on the screen
42"plasma tv sound no picture
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
SOURCE: The screen on my Gateway Plasma 42 in TV went
I have over 10 years experience in electronic tech support.
I
know this isn't what you want to hear, but the problem you've described
can't be fixed with troubleshooting. Your TV will have to be repaired.
There is a part that has developed a defect and needs to be replaced.
The question will be, is the part still available? Before paying a TV
repair person $75+ to diagnose the problem, ask yourself if you're
willing to pay $250 minimum to fix this particular set. Also keep in
mind that most TVs that old have a very limited number of replacement
parts still available. Normally it will cost at least $75 to have the
set looked at by a repair shop (diagnostics). If the part needed to
complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
SOURCE: TLX-03210B blanks out, audio works, with some smoke as well
Open the cover and look for the burned componet.Usually it must be a condenser. Rarely a resistor.If it is a condenser just replace it with the similar one. Note the polarity while replacing. If it is resistor need to check the associated circuit for over load. If you not sound in electronics reffer to an expert.
SOURCE: I was watching tv and the screen went blank. It
You would have to try an INIT and see if it causes the tv to be operational again. It is something that you have to be walked through step by step by step and can erase the memory of the tv if done improperly. Call Sharp tomorrow morning at 9AM CST and someone can walk you through one. Call 800-237-5277 or if you have an aquos advantage model call 87-332-7867
