My fridge started making noises a couple of weeks ago. I thought it was normal since it always had been loud. Yesterday I found out it was warm inside refrigerator & freezer....it sounds like the compressor isn't running. You can here the refrigerator trying to kick on the compressor but it doesn't come on
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
SOURCE: maytag side by side slowly getting warmer
I
have actually been having the same problem. We have a Maytag MTB2156GEQ
and it hasn't been cooling well at all lately. Temp in the fridge is
about 52 degrees even on the highest setting. The freezer seems to be
fine. I pulled off the back panel and vacuumed out the condensor coil
and everything else under there. I then pulled out the control panel on
the ceiling of the fridge. The channel between the freezer and fridge
was almost completely blocked with ice. I cleaned it out by taking out
the back panel of the freezer and pouring hot water down through the
hole until it was clear.
that seem fix the issue.
SOURCE: kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
SOURCE: Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
SOURCE: REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
Testimonial: "It was the compressor. Bought a new Amana and it's great! Hate Sears still;)"
