Tasco 2023 BRZ rubber eye pad
SOURCE: my lens is out on my tasco 10x50 mm zip focus 2023 brz wideangle
Crazy glue will sometimes leave a white cloudy film on the glass surface. I've had good luck with www.binocularservice.com and they are very reasonable too.
SOURCE: replacement parts for Tasco binoculars
You'll need to measure your eyepiece in "mm". Also determine if your eyepiece has an outer ring the eyepiece will slip over. You can find eyecups/guards on Ebay. Search under Binocular Eyecup or Binocular Eye Guard. There are also eyecups under "rubber eyecups/rubber eyeguards" but alot of these are for Microscopes and may not fit. You will need to pay close attention to the mounting type and measurements.
SOURCE: I have an old tasco 7x-15x35 zoom binocular.
Measure the diameter needed and then check bicycle inner tube diameters. Cut a short section, roll a quarter-inch inside-out, slip over the eyepiece, roll the other end inside-out to form a nice soft shoulder. Costs nearly nothing, works dandy.
