Even though the ignitor seems to glow bright orange,it still maybe weak,as in not enough current to open the gas valve,an easy test is to just swap out or interchange the broiler ignitor and bake ignitors and see if this takes care of your issue on the lower bake side as most units use the identical ignitor for each upper and lower manifolds and the gas valve supplies both the bake and broiler manifolds depending on which you choose to use bake or broil
Testimonial: "You are a stud, can't believe I didn't think to swap them out. The oven works great and now I know the part to order to fix the Broiler. Thank you for the suggestion, much appreciated!!"
When I shut the manual gas flip valve closed and reopen slightly I can hear the gas flow and the oven lights, but the element goes out in a few seconds. Any ideas?
