I need a wiring diagram for shark iron g1490 11
SOURCE: My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
SOURCE: my shark steam iron is leaking when ironing
It is quite possible that this is a defect in the shark G1490F... I had the same problem and it was a crack in the water holding tank caused by tightening the two front screws (hidden) that hold the tank to the base... It seemed fine at first but after a full heating it developed a crack where it had been weakened when it was assembled... I suggest returning it or if warranty is up , throw it away and get something else..
SOURCE: shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
SOURCE: Iron quit working in less than 1 year.
Bought my Shark G1400Z iron about a year ago. The iron caught on fire. Luckly I was only out of the room for a few seconds. What can be done about this?
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories
heatman101
