SOURCE: leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
SOURCE: Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
SOURCE: i need directions for kenneth cole unlisted watch aul1084
how do i shorten the watch band without breaking it???
SOURCE: hello, i bought a keneth
KC are hard ones to find manuals.
Best I can tell you is to call them at 1-800-KEN-COLE.
Best of luck.
Jewel
