The Plasma picture stays on about 30 seconds then we lose the picture and the red standby light comes on steady then begins to blink about 6 times then steady and then 6 blinks. What is wrong with our Panasonic TH-42PHW5 Plasma?
Five blinks - AKB
circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on
the A board. In addition, unit could be in IK blanking, try turning
up screen A2 slightly.
HIS DESCRIPTION OF THIS IS EXACTLY WHAT IS GOING ON WITH MINE.
Blinking 5 times...won't turn on and the power goes off after about 20 seconds...doesn't show in the manual...what is the issue on this? Fan, power supply, other?
Hello I have same model TC-P42X1. Mine turns on then off and cycles 3 times and then shuts off completely. No error code. steady red then off completely. Is that a picture out of a training book? where it says 5volts on pin 9 of P25 means the A board is bad. I do have the five volts. What normally fails on the A board? where can I buy training books like this?
What does two blinks indicate? Thanks
What does two blinks indicate? Thank you
