SOURCE: My machine jammed/bent needle & gave error message
p { margin-bottom: 0.21cm; }
Hi, According to your problem, if you have
change/replace the niddle properly then you can try to change the
niddle position to solve your problem. Check the niddle threading and
reset it. Check also the thread sensor. Reset the machine and unplug
it after resetting for 2 min. Then plug it and turn it on again. If
it doesn't solve your problem then you may need to reload the
software.
