The security lock is on and i have forgotten my pin number
You can unlock your Nokia 3310 at wickedunlock.com using Master reset codes!! Specify your phone's manufacture, model and IMEI number to get the codes. At wickedunlock the codes are affordable and also the unlocking process is simple!!!
SOURCE: Nokia 5300 Security Code problem
try 12345 if that dont work you will need to ring up nokia and tell them your imei no and they will provide you with a security code
SOURCE: forgot the security code
hi if the phone is asking for the security code as soon as you switch it on then i can give you the master code that resets the code to what it was when new usually 12345 the code only works if its asking for security code when you switch phone on.
Also the code is only accepted if the code hasnt been entered wrong more than 5 times if it has been entered wrong more than 5 times then the code wont work the code is in my next post ok let me know if you need further assistance ok
SOURCE: 3310 asking for security code...
The default is 12345. If you've changed it to something else use a
data cable and the Logomanager program and it will reveal the security
code.
SOURCE: forgotten security code for nokia 6101
IMEI: 359387008353037Mastercode: 2336522362
Use this calced 10 digits mastercode at the same points where the phone normally asks U for the security code.
Frequently Asked
Questions (FAQ)
