Televison & Video Logo
A
Anonymous Posted on May 28, 2012
Samsung ln46a540p2f lcd tv power problem
Clicking when turning on tv, but tv doesn't work
5 Related Answers
Anonymous
  • Posted on Jul 13, 2008
SOURCE: Samsung LCD TV shut off, wont turn back on...?
My samsung lcd is doing the same thing, and I have been told that the power supply is bad. But apparently samsung won'r sell you one.
Anonymous
  • 43 Answers
  • Posted on Jul 04, 2009
SOURCE: Samsung LCD 40" While LInes, Clicking Noise, Red light blinks
Your LCD has gone bad or their is a high voltage problem that powers the LCD. Usually a inverter board.
Anonymous
  • 7 Answers
  • Posted on Sep 25, 2009
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
DH
  • 22 Answers
  • Posted on Feb 22, 2010
SOURCE: Samsung 40inch LCD tv doesn't turn on for some
To all who are having power supply issues: Samsung is now acknowledging a problem with the faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Anonymous
  • 131 Answers
  • Posted on Apr 05, 2010
SOURCE: clicking sounds and delay when turning on lcd tv LE52M86BD
Hi
A common fault with this model is bad capacitors in the power supply, Remove the back from your tv and look at the power supply for bulged / swollon capacitors on top, they may even leak a brown like substance and should have a value of around 1000uf 10v
Change these where possible with the same uf but higher voltage lets say 1000uf 25/35v
Hope this helps
Please rate my reply++++
Samsung ln46a540p2f
Visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
2answers
Bn44-00167a kit power hansol
Just search for the site named Electro-help. It has details about repair. I assumes that you're somewhat sound in electronics. You can get details there. Search for the site by Google
SAMSUNG Le32b450 DOESN'T TURN ON
check or have checked the power supply in this set, if not able to do it yourself have a tech or a shop examine it.
Samsung lcd will not power on
check for blown fuse, if the fuse is good replace bulged capacitors. if still doesn't works tried to remove the connector going to the inverter board for screen back light might have shorted line that can cause of power failure.
1helpful
Samsung lcd has no power, the red power light doesn't even come on. Could this be a fuse? Power supply board? If so, where are the fuses located?
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Can't turn it on - the power lught is flashing
it is possible that the tv is in its power management system because it was over heated. Leave it alone for a couple hours and if it still doesn't turn on, try unplugging and plugging it back in.
Hi - My Samsung LNT5271FX 52" LCD TV won't turn on. It just clicks over and over and over, but never turns on. What's up? A relay?
This is a capacitor problem. Several Samsung models have bad capacitors installed on the power supply boards. Samsung currently offers a recall fix for this and other models. Call Samsung direct to see if your TV qualifies for this one time fix. It is a free fix, so if the person on the other end doesn't have a clue, ask to speak to a supervisor or hang up and try again.
Goes off & comes back on.. now stays off Samsung model LN46A540P2
This could be 2 things, a main board or a power supply. I have replaced many main control boards on samsungs and it solved the problem. But sometimes it could be the power supply. You will need to test the voltages on the power supply to rule out the power supply being bad.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
