TV shuts off and when you try to turn it on the green power light comes on for a second and shuts off. I tried the diagnostic code and got a sequence of 2 blinks then 3. Does anyone know what this points to?
2blink-then 3 blink---------deflection circuit problem
It is a little misleading but means something in Horizontal or high voltage circuit (covers a lot of area inside the set) is bad.
Going to need a service manual, etc to try to track it down.
Entire chassis for this set can be removed====called a light box.
SOURCE: mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
SOURCE: Mitsubishi WS-55819 TV Wont turn on.
code stands for loss of vertical. I had one of these if you can check pico fuses, check the ones on the main power board the one with the 2 convergence amps if any of them are blown then most likely the convergence amps have shorted out.
