Tried all the Westinghouse, Samsung and Sony codes (per Westinghouse support) and found many codes that would power the TV off and on, but none that would control the volume.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not
in the address bar of your browser], and click search. It is an electronic equipments service help
site. All details you want are
there. Note the position of
hyphen in between words in site name, when you type it in. The site will appear as it is in
web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts.
You can get all details.
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
SOURCE: cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
SOURCE: Cannot program Verizon FIOS remote with RCA
Talk to Verizon,should not require code because u using verizon remote on verzon box.
SOURCE: virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Sadly there were no posts regarding Westinghouse. Appreciate the help though.
