Question about Philips CCC130AT 13 in. TV/VCR Combo
Tv channels are not coming in
I can play the vcr, with no problem, but i can't get any cable channels, I have reset the channels, unplugged the tv for many hours, still unable to watch tv, but can watch movies.the screen comes up snowy, i have even checked the cable with another television, and that worked fine.
    Scholar:
  • 168 Answers
It seems that there is a problem with your tuner. check inside if there are cold solder especially the rf connector jack of the unit.
Posted on Jan 19, 2007
Anonymous
SOURCE:
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
    If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
    If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
    May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
    No channel below 7 when hooked direct to cable connection. Reset and auto program channels , only get 7 and up. This makes it unable to use VCR tuned to channel 4 or 3 . As well as not getting the lower...
    low band in the tuner is bad .the tuner needs replacing. simple way to fix it use vcr or dvd with tuner
    in it use video inpiuts on tv and use the tuner in vcr or dvd. works great
    bc
    Feb 25, 2009 | RCA F32650 32" TV
    Unable to separate VCR playback from Sat. Receiver input,both av2
    try to find a multi-video selector swicth that the best you can do
    Dec 19, 2008 | Dynex DXR24TV 24" TV
    Have cable tv and wanting to tape a certain channel
    I would suggest that you disconnect the VCR from any signal source. UNPLUG the VCR from the power source [a/c] for at least one hour, more if possible. Before you are ready to plug the machine into a/c attach an antenna to the antenna INPUT, the VCR output goes to input of tv. [ DON'T attach cable box, or any such machine to the input of VCR.] Plug vcr into outlet and turn ON. Place TV-VCR switch on TV. [no remote control??] Change the channel MANUALLY, one channel at a time. If you see tv stations as you change the channel [KEEP changing until you have reached the " end of the line " of broadcast channels.] then you are good.Connecting the vcr to a cable box[ANY KIND!] you can only RECORD through the vcr what you watch on cable.
    Dec 09, 2008 | Sanyo VWM-900 VHS VCR
    Playing vcr causes new digital tv to lose saved channels
    Vizio representative suggested connecting antenna directly to TV and not through the VCR. In doing this, we lose the ability to record on the VCR but we record elsewhere and watch downstairs. The problem is solved on losing channels. I must add that we watch and record on a Sharp digital TV upstairs and do not lose channels. I don't know why the VCR had this effect on this Vizio TV.
    Dec 01, 2008 | Vizio L37 Television
    Unable to record vcr while dvd playing
    are you trying to record the dvd or tv or cable channels let me know then i can help
    Jan 08, 2008 | Televison & Video
    TV seems to be "stuck" in VCR mode after power surge
    your tv is playing dvd means your video &sound section is ok. as it is not playing cable means that there a problem in tuner section only. if cable connection &its socket is ok.
    Sep 25, 2007 | Philips TS2768C 27" TV
    Tv wil not change channels unless vcr is on
    You must go into the menu, go to the channel setup and do a channel scan.. Your TV simply lost the channel memory. Good Luck
    Aug 16, 2006 | RCA 6' Video/Optical Combo Cable -- DT6VHP
    Philips CCC130AT 13 in. TV/VCR Combo Logo
    133 people viewed this question
    Top Philips Televison & Video Experts
    ThaMp3Doctor
    ThaMp3Doctor
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
