JUST KEEPS CLICKING WHEN POWER IS ON
SOURCE: Samsung LN-T4032H LCD
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: samsung lcd tv le40r8. tv will not switch on.
The problem is the mainboard tried to turn on TV but failed due to internal circuit problem. Normally, the power supply board is malfuntioned.
SOURCE: samsung lcd wont turn on just keeps clicking
Check for swollen capacitors on the power supply board.Very common problem on samsung lcd tv's.
SOURCE: My Samsung LCD tv clicks over and over again but won't power on
this is common fault the capacitors have blown on main power board you can replace your self if got soldering iron
take back off tv and look for capacitors that have RAISED TOPS they look like little batteries with white line on one side and numbers (e.g 2000mf 25v ) the best way to remember which way they go back is take picture
you can get parts from charles hyde and sons web site (CHS) under general components or at a electronic shop
SOURCE: samsung ln-t4053h 40in lcd will not power on
my samsung when switched to the hdmi inputs comes up with a box saying not supported mode?? how ever shall i play my ps3 now?? can anyone help??
