Mesa Safes MFL2014E Safe Depository Safe 09 Cubic Feet Logo
amit kumar Posted on May 29, 2012
Forgot mesa safe lock combo mfl 5oo
Wrote down my dual custody numbers and cannot find the paper please advise
Casey Gunter
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jun 08, 2015
Casey Gunter
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
10482
Points
18
Have you changed the factory set Master Code?
Mesa safe digital code forgot code
You need to communicate with the manufacturer. Maybe they will help.
Sentrysafe forgot combo 1310 sn #1750619
refer to the manual that came with the safe it will have a master code included or instructions on how to reset the unlock code or you can contact a lock smith or the manufacturer and they will be able to assist
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Common Issues with Mesa Safes MFL2014E Safe Depository Safe 09 Cubic Feet
The most common issue with the MFL-2014E is the keypad. We have 7 of these safes in our company and I had been replacing the keypads all the time. Which wasn't too terrible while they were under warranty but if I remember correctly they want $60 for a replacement keypad out of warranty.
I started replacing the electronic lock and keypad with Sargent and Greenleaf models. S&G 6120-305 or S&G Titan 2006-108 and haven't had problems since. Mesa said they had an engineer team from overseas go over their keypads to figure out what the problem was. The feedback was their design was fine but the components were cheap and under par. I still had a problem with their resigned keypads however.
The only other problem I have had is the bars getting bent from people shutting the door on them and bending them. This can be fixed by taking the panel off the door and bending the bracket back flat with your hand. The metal there in a bit too flimsy in my opinion.
Suddenly we can't open our Church Safe. It has worked fine for almost 2 years. We have replaced the batteries with new fresh ones but still can't get the electronics to allow us to open it.
Hi.
The safe can lock up under determined conditions. Since safes are security anti-theft devices, in case they do not open, they can only be accessed with the help of the manufacturer.
Please, call Mesa Live Technical Support. The operators are available Monday - Friday 8:00am - 4:30pm (Pacific Standard Time)
The phone number is toll free. Here the number: (800) 490-5624.
Using Mesa online page you can also identify the model and download the manual. It is better finding out the safe model before contacting the Mesa by phone, so to speed up support operations.
Please click here to access Mesa support page.
Regards.
Ginko.
I forgot my combination i tried putting a couple different numbers in after three trys the key pad locked and now when i type any numbers in it doesnt work. how do i unlock my safe?
after 3 trys the keypad does go into lockout mode but it should only last for about 15 minutes and then let you retry 3 more codes to try and open. if you still do not know what the combo is you can usually call the maker of the safe and with the serial number you might be able to get the original combo that the safe was set to when it was purchased ( this is a factory set combo ) --- now if that does not work, your next step will be to call a safe tech ( locksmith ) to set up a auto dialer,, this takes about a full 24 hours to get the combo right. the safe tech can also drill a small hole behind the dial and manually remove the locking bolt. after the safe is opened the locksmith will fill the hole and reset the combo for you ( also replace the battery at this time too ).
c...
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
3helpful
3answers
Can't open sentry v260 safe
Make sure you are inserting key so the round hump on key matches red dot on lock, and turn key clockwise.
If that doesn't fix it, SentrySafe's support number is 1-800-828-1438.
I would think they can confirm the combination from your serial number. They probably won't give you the combination without a notarized letter, but if you have the right combination for that serial number safe, they may confirm that you are entering the right combination.
Be aware the 4 number combination V260's are changeable and if you HAVE changed it, you are on your own, they can't help you. The 3 number combinations are not changeable.
Forgot the code to allow movies to play on play station
press 'select' button, enter 7444. enter new password, then re-enter new password. 7444 deletes previous password.
Top Mesa Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Mesa Home Security Expert? Answer questions, earn points and help others
