Try booting in safe mode and see if the screen displays properly. Turn off the computer, then hit the power button to turn it
back on and immediately start hitting the F8 key repeatedly until you see SAFE
MODE. Take the Safe Mode option and let it boot up. Safe Mode will look
different to you, the screen will be darker and the icons bigger, this is
normal. Try connecting another monitor to the computer.
Borrow a monitor from a neighbor, friend, relative or co-worker and
connect it to the computer. If the Borrowed monitor shows the 1 inch
black space then your video card might be going bad or you might have a
virus infection. If the Borrowed monitor displays ok then your original
monitor is bad.
SOURCE: My computer takes over 5 minutes to start up. Too many icons
its better to go to the run command
and type MSCONFIG
here you will find out stratup tab
go to it and uncheck unneccessary program
then restart the system
SOURCE: restarts or reboots screen reads "diskett 0 drive failure"
1024 X 768 is the ideal setting for a 17" Monitor. Are you still getting sound output despite the error message? If no sound then your integrated sound card has failed, you will have to install anew one in the PCI Slot, otherwise forget about the warning & keep listening. You could try visiting the Official website to see if any driver updates have been released till date and refresh the drivers(sound) installation...............sodeep
PS: Check your Floppy drive? If not working simply disconnect and likewise in the BIOS if REQUIRED.
SOURCE: I "kneed" my DVD tray and knocked it
They are very easy to replace. I have never had much luck trying
repairs. And too they are only about $20-$25 if you shop carefully to
replace.
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1056445
click on the link above and there are directions on how to pop it out and pop it back in again.
You can do it, take you time and go step by step.
and too there are some great illustrations to get you through it.
I'll give you another link (below) to a place where i shop, good prices, reliable, very fast...(newegg.com)
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=5&name=CD-DVD-Burners
$24.95 no tax and free shipping...
hope this really helped, please leave a rating
thank you kindly
SOURCE: My wife deleted our SOPHO-Anti-Virus. So I tryed
If she just deleted and did not remove properly via "add or remove programs", you can try going to your "recycle bin" and just restore the deleted files. You will need to double click on the recycle icon and find your deleted files. If you find them, just right click on them and click restore.
If they are permanently gone, you will need to reinstall the program either from http://www.sophos.com/ or find the install cd software.
The 3rd way you can restore them is to do a "system restore"
click start, all programs, accessories, system tools, system restore
You will need a date before you wife deleted the files.
Testimonial: "Thank You For All Your Help."
