I have a Maytag Neptune Front Loading Washer. All of the lights on the top come on, and I am able to adjust the water temperature. When I hit the start button, it does nothing. I have unplugged it for a while, then tried again. Once it helped, and I was able to get the thing to start. I haven't been able to get it to reset, and start washing clothes.
SOURCE: nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
SOURCE: maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
SOURCE: i have a maytag neptune washer the water will not drain out of it
Check for obstruction in pump located at back of machine. Remove back panel and pump will be located on left hand side.
SOURCE: front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
Take out the inserts and rinse them and the drawer thoroughly.
Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
