It was built approximately 1994/1995, is a 5 cycle heavy duty large capacity machine which measures 26 1/2" wide by 24 1/2" deep.
SOURCE: kenmore heavy duty clothes dryer will not heat
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
SOURCE: Kenmore Heavy Duty 60 Series Soft Heat Large Capacity Dryer
i need to take the bottom lent door off. I have replaced the board and it still say's says to clean the lent door. i have with the one in the dryer, but need to clean the bootm .
SOURCE: Dryer only blows cool air
my dryers works just blows cold air,can you help?
Thanks,
Xavier
[email protected]
SOURCE: GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
SOURCE: I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
